Electrical wiring and measuring whole house electricity use
Measuring whole house energy use in the UK.
If its a house in the uk it will probably be a 240VAC 2-wire single phase system.
To measure energy use you need one current sensor and one voltage sensor, see the diagram here:
Here's a picture of the current sensor connected to the main live coming in to the house:
Measuring whole house energy use in the USA
If its a house in the us it will probably be a 120VAC 3-wire single phase system.
To measure energy use you need two current sensors one on each leg and one voltage sensor, see the diagram:
The combination of both legs is simply summed:
Total real power = real power leg 1 + real power leg 2
Wiring diagrams modified from hyperphysics.
WillemK's picture
3 fase system
Hi Trystan,
I was wondering how much effort it would be to use this system on a  3-fase house energy system. I don´t know about the UK, but on mainland europe, if you have a Heat Pump, you have a 400v system, consisting of a 3 fases of 230v and a 0, and earth. I have this drawn in the same fashion as the drawings above, and I´m sure there is enough intrest for a monitor in this configuration.
As far as I can tell, in this case you need 1 Voltage sensor and 3 Current sensors. But is this still possible on the standard Arduino board, and I guess you need to modify the software. In the ideal situation I´d like to monitor my total use of energy and what the HP uses. This askes for the need of 3 extra CT sensors, or as in my case, a pulsecounter for the pulses from the energymeter on the WP. Logging-wise I understand how to handle the info from the database and create a graph with the use of "normal" energy and on top of that the energy used by the HP.
If you´re intrested I gladly sent you the drawing.
Thanks,
Willem.
re: 3 fase system
Hey Willem
I think it certainly should be possible to monitor 3 phase, the sampling rate on the arduino would be a bit slower than for single phase due to need for extra analogRead()'s but Im sure it would be enough, I haven't done it myself yet and am not entirely sure of the theory or how the code would work out.
There's some info on 3 phase at allaboutcircuits here: http://www.allaboutcircuits.com/vol_2/chpt_10/5.html
Im very much interested in finding out how to do this so if you do work it out let me know
Trystan
Amin Zayani's picture
Power factor can be negative
I noticed that when the polarity of the AC-AC adapter is changed, the sign changes... I understand why, but do you think we can find a way to make it irrelevant in the setup?
(like software correction or so?)
Re: Power factor can be negative
Yes shouldn't be too hard to do. We could add:
if ( realPower<0 ) realPower = realPower * -1;
just after the line that calculates realPower from the sum of the square of instP
 that was my first thought,
 that was my first thought, but I had some doubts... :)
