Absolute value kWh
Hello!
How can I set up a statistic for daily/monthly/yearly used Power?
I get the absolute value of the total power consumption.
24678,8 ... 24678,9 ... 24679,0
But what feed I have to use? Because I have no Power or Power/day information.
Thank you!
Eric_AMANN's picture
Re: Absolute value kWh
It should work with the "kWh to Power" process and then the "Power to kWh/d" process.
Eric
unique24's picture
Ok, guess I found my problem.
It updates with other values sometimes ZERO values.
Now it seems he calculate correct.
Thank you!
