Notify module
Hello everyone,
I installed Emoncms on MY QNAP NAS and everything works very well.
After I installed the add-on "Notify"  following the instructions on https://github.com/emoncms/notify.
When I try the php script "cron.php" from console appears the error:
"mysqli :: query (): Unable to fetch mysqli in / share/MD0_DATA/emoncmsdata/cron.php on line 33
PHP Fatal error: Call to a member function fetch_object () on a non-object in / share/MD0_DATA/emoncmsdata/cron.php on line 37 "
Any ideas?
James's picture
Re: Notify module
I note your comment that you have Emoncms installed and running on a QNAP NAS. Can you elaborate how you installed emoncms?
​I have a QNAP 469 Pro. Linux NAS, running QTS 4.1.2. see www.qnap.com
QNAP Forum has an attempted install, which aborted, see. Unfortunately QNAP NAS nas does not have apt-get, pecl or pear. I have optware installed and can easily ssh into box, but stumped how to proceed.
Any help, gratefully received.
