Input sign Emoncms
Hello, i need some help, i'm new in emoncms.
How could change the sign of an input?
Re: Input sign Emoncms
Hello riverc1, you could use the scale input processor and multiply by -1. Is it one of your emontx power channels that are negative? if so could you flip the CT sensor?
riverc1's picture
Hello TrystanLea, thank you for your response.
yes, one of my emontx power is negative, i'm using scale input for multiply by -1, but the result is not correct and i don't know why
Can you expand on "not correct" ?
That is the normal method and it usually works so some info on what values are you using and if there are any other processing steps or what version of emoncms you are using etc could help determine the issue.
Also tell us what your wiring system is, what inputs your EmonTx is using and where your ac-ac voltage input and where your current transformers are placed.
