Can't edit oemgateway.conf on windows xp
Hi All
I've spent a morning trying to edit the oemgateway.conf file on the SD card.  Windows XP just asks if I want to format the card, Ext2Fsd doesn't see it, Linux Reader is read only, I've tried a VM Player linux install and I can't make the mouse work to be able to use it.
Any other ways of doing this - please don't say I need a Linux computer to change the API key!
phildabeast's picture
Re: Can't edit oemgateway.conf on windows xp
I also learned how to use putty and nano to log into the PI to manually edit the file, but the whole point is that it's a read only file system.
also using ipe-rw doesn't allow me to use chmod
Using putty you can change read only access to read and write using
   ipe-rw
at the command-line, edit using
   nano /boot/oemgateway.conf
and then use
   ipe-ro
to make it read only again.
http://nutcom.hu/?page_id=147
answer within! phew!
ahah.. well spotted its handy to know.
EnergyRnR's picture
+1!
