If I may ask for advice,
I am using the EtherCard library on my NaNode and I want to build customizable settings thru HTTP web site on the nanode itself. One of the settings is user configurable NTP server (as a site, not IP).
It turns out that the EtherCard ether.dnsLookup fuction expects a progmem string.. so I can't just lookup an EEPROM saved configuration for NTP server.
Is there any way to work around this?
ok, I figured it out. I had
I had to modify the EtherCard library, dns.cpp so it takes regular char* instead of progmem.
This sounds interesting,
This sounds interesting, please post up an example when you get it working.
This whole project is about a
This whole project is about a NaNode controlling my Daikin air conditioner via IR codes (I decoded the protocol).
As for the EtherCard modifications, quite simple indeed:
Just edit dns.cpp and modify the line:
//static void dnsRequest (const prog_char *progmem_hostname) {
for(;;) {
// originally c = pgm_read_byte(progmem_hostname++);
c = *hostname++;
if (c == '.' || c == 0)
//bool EtherCard::dnsLookup (prog_char* name) {
bool EtherCard::dnsLookup (char* name) {
and of course modify the EtherCard.h
static bool dnsLookup (char* name);
Here is a glance of the UI, I use jquery mobile and it is optimized for use via phone.
My nanode finds its external IP and publishes it to DynDNS (still no UI, this is my next todo).
I have also implemented Basic HTTP authentication security scheme so if someone accidentally lands on the page, he doesn't mess with my Air Conditioner
Please don't ask for the code, I intend to sell these gadgets in the future.
