Raspberry PI gateway ok only with dhcp...
I had many issues with frequent raspberry PI lockups when using SD cards running emoncms (v4 and v5, did not try v6).
I decided then to switch to "pi gateway" and the system is running like a charm! Thanks!!
The only issue I have is that I when I set a static IP address on my raspberry data forwarding to emoncms does not work.
If I go to root/oem_gateway   and relaunch the py script (after killing old process and configuring oemgateway.conf there) all works...
I cannot see the relation between static IP and the gateway function....
(Note: static IP address and gateway is fine since I can reach my raspberry using ssh from internet...)
Anyone got similiar issues?
Scarlaz's picture
Re: Raspberry PI gateway ok only with dhcp...
solved!
It happened that with fixed ip the name resolution was not working. Had to install resolvconf
now is ok. Maybe it is an issue with the distributed image.
rmce's picture
Hi there,
I was facing same issue and was solved following Scarlaz's notes:
1. Enable RW and DHCP for eth0:
# ipe-rw
# nano /etc/network/interfaces
auto lo
iface lo inet loopback
iface eth0 inet dhcp
2. Install resolvconf
​# apt-get install resolvconf
3. Set static IP and disable DHCP for eth0:
auto lo
iface eth0 inet static
address 192.168.1.96
netmask 255.255.255.0
gateway 192.168.1.1
dns-nameservers  8.8.8.8 8.8.4.4
4. Restart Raspberry Pi:
# reboot
Hope this help.
