Emoncms and Rain Gauge
I have wanted to log rain fall for some time in connection with our solar powered irrigation system. I asked on the forum about using a wireless Oregon gauge we already have but hooking it up to the emoncms radio system seemed like a lot of work. I then considered hacking an emontx into the Oregon but soon realised there would be waterproofing issues.
I then found a rain gauge available as a spare at a very reasonable price.
Available here:- http://www.radioworld.co.uk
Search for 8681-RGC
It has a long cable with just 2 wires. The device contains what I think is a reed switch that sends a pulse every time one of 2 little buckets fills and tips the second bucket into the monitoring position. I already have the pulses reading into a battery powered emontx. The next step is calibration and then setting up the feed. I already have a waterproof  emontx monitoring outside temperature. I hope to be able to combine rain gauging and temperature reading into a single unit.
I thought this may be of interest to others.
Ian
Mattia Rossi's picture
Re: Emoncms and Rain Gauge
Hi Ian, nice find.
I bought the whole sensor lot (less the base station) for 40 euro shipped, and then paid less than 10 for a rfm01 receiver to read the data .. And i didn't have a waterproof emontx on hand. But 10 pounds is really hard to beat as a base price...
It would be great if when you're done you posted the code you wrote to keep as a reference.
Mattia
9fingers's picture
The Radio world shipping adds nearly 50% to the price.
The same part is available including UK shipping for £8 here
http://www.ebay.co.uk/itm/Spare-Rain-Gauge-For-Use-With-Wireless-Weather...
Bob
warlock's picture
This looks really interesting, I would be keen t see this work, and for a pounds from Maplin this is a real bargin.
warlock's picture
Hey Guys,
Has anyone managed to get this working and connected to an emonTX v2, I would like to do this but not really sure where to start, I have the rain gauage, so next step would be to connect to the emonTX, I assume to 1 of the analog inputs ?.
Any help would be appreciated, with some sketch information too.
Thanks in advance.
Ian Eagland's picture
It needs to be connected to a digital input. I found I had to use hardware debounce as the reed switch is very noisy.
I can upload my sketch if it is of interest ( its not elegant but it seems to work )
Ian
sumnerboy's picture
I would be very interested to see your sketch Ian - I have one of these rain gauges from an old weather station and would love to hook it up to an Arduino to monitor rain fall.
Cheers,
Ben
I've just had the same issue except whilst reading a microswitch. I overcame contact bounce by using this software example, which is simple and worked very well, and stops the state from changing for a predetermined time. I found 20 milliseconds worked fine for me.
warlock's picture
Hey Ian,
I would really appreciate it if you could upload your sketch, aslo I suppose I can use the spare digital inputs ?
for example I would connect the 2 wires from the raid gauge to say DI06 and GND ?
I tried software debounce with very little success. I then read this thread:-
http://openenergymonitor.org/emon/node/5022
It suggests software debounce should not be used in interrupts.
Warlock
Code attached.
Ian
Ian, I used the software debounce to halt and put the processor to sleep, rather than wake it up! So yes I can see the difficulty.
