Change 'snap to' grid size - Extended Version
Anyone know how to change (or disable) the dashboard 'snap to' grid size?
Currently it's quite coarse, and trying the method described here made no difference.
I realize that I could edit the coordinates in the sql table to position items precisely, but it's not ideal....
chaveiro's picture
Re: Change 'snap to' grid size - Extended Version
It's tied to grid size (the dots).
On Modules\dashboard\Views\js\designer.js
You can change the pixels size in line:
    'grid_size':20,
Or untied it by replacing:
    'snap': function(pos) {return Math.round(pos/designer.grid_size)*designer.grid_size;},
With:
    'snap': function(pos) {return Math.round(pos);},
The first suggestion - changing the pixel size didn't work for me (or another member) but the second option of untying it completely did work OK.
- Just trying a different approach in laying out a mobile dashboard!
dockarl's picture
Thanks for the heads up on the solution Paul!, and thanks for the suggestion Chaveiro..
smitt1979's picture
The first suggestion - changing the pixel size didn't work for me either but i did find a fix you can edit the line as below to change the pixel grid size
'snap': function(pos) {return Math.round(pos/5)*5;},
Steve
