Packetgen and button on dashboard
Hi all
now that i figured how to setup the extended branch and get mysql running i wanted to add something more
i came across this one
http://openenergymonitor.blogspot.dk/2013/12/emoncms-control-development...
and i thought i could use a single button like that for my heating, right now it runs for 2 hours each morning and that is ok in most cases.
thou there are some times that i get up before there is hot water for a shower and i need to set the alarmclock 1 hour in advance, get up and turn heating on, then back to bed and sleep and then up like i planned
a simple button could work as i could then turn on the heating from the bed..
ideal a small box with on and off times and enable, i dont need a full week schedule with multiple periods a day since this is just for those rare days
like the demo said i tried to dump all the files in a folder under modules but that crippled every page in emoncms
have anybody tried like i want before?
i did manage to make a sketch for emontx v2 that are able to both collect data and control the hotwater via a relay, at least it compiles and the logic seems simple enough. just need to find the time to test it
boelle's picture
Re: Packetgen and button on dashboard
this one is just to get an e-mail when there are a reply... the options where not below the text box on the initial post
boelle's picture
no one done this before and can share how?
boelle's picture
really? no one tried this yet?
boelle's picture
Hmm...
still a bit confusing to me... i get that i need to draw the botton on the dashboard and create a feed for it
but then i'm lost on how make the feed value send out the packet to the emonTX
i liked the youtube video trystan made for his boiler, but a more in depth desciption would have been nice
boelle's picture
no rush...
the dials etc does not show up, even thou dashboard and feeds are set to public
EDIT: basicly this is what i want: https://www.youtube.com/watch?v=C4WGaiw7jyo
but with a bottom next to the cylinder on the dasboard so i can tell the OpenTRV unit to heat up on those rare cases where i need hot water at odd events
boelle's picture
revisting this one again....
i read that other thread and it was only  confusing to me
or maybe i understand it correct.... that zip contains the js file that is the widget right?
and that creates the button seen in the post made Thu, 08/01/2015 - 09:11
so i assume that this button just changes the feed value....
but how can i now change a value in the packet generator?
boelle's picture
read this blog:
i copied over the demo files and i got the myheating page... but that page never shows any of the buttons
EDIT: now the nest dial shows up... but since i have not figured how to change settings etc it reads NAN all over
i was hoping to see the simple button only
EDIT2: think i got it.... /emoncms/myheating/button is the link for the button... now i just need to get it to work :-P
EDIT: in packetgen i hit reload default packet and i can now change the button... but it does not change the value from false to true and vice versa
boelle's picture
btw... will packetgen also find its way to V9 ?
