Where is the TimerOne.h header file? It is nowhere on Github
Trying to compile the emonTx Discrete sampling.
It is looking for TimerOne.h. Is this a emon specific header filer. It's not finding it, and it is not on github
Re: Where is the TimerOne.h header file? It is nowhere on Github
Not that I recall and a quick Google suggests otherwise too!.
What sketch are you loading specifically? a link would help as a search of the emonTx Firmware repo only finds 4 instances, none of which are a Discrete sampling sketch.
alexkarstens's picture
How are you trying to compile? (Arduino IDE? Version?)
Is there anything else in the same directory as your sketch?
AdrianSmith's picture
Hi, I am also trying to compile the "emonTxV3_4_continuous_kwhtotals"
 it has "#include <TimerOne.h>" as the 4th line In the source listing; and I am getting the same problem with the error message "emonTxV3_4_continuous_kwhtotals.ino:17:22: fatal error: TimerOne.h: No such file or directory compilation terminated."
I am able to compile the "emonTxV3_4_DiscreteSampling" OK.
Simon's picture
Timerone.h is a standard Arduino library.
http://playground.arduino.cc/Code/Timer1
There are some newer/modified versions for example
https://github.com/PaulStoffregen/TimerOne.
But I used the standard TimerOne and it worked fine.
What I don't understand is why alexkarstens cannot compile the default sketch, which does not require Timer1. Hence the supplementary questions. I suspect he doesn't understand how the Arduino IDE expects him to work (not surprising really as it got a few idiosyncrasies), and he's got another file in the same directory.
[Simon, in this day and age, people need to learn how to use the search engines effectively, hence the nudge from Paul.]
