Problem - Dashboard-->Widgets-->feedvalue
Since few weeks I've a problem with the visualization in my Dashboard.
All feedvalues are only showing a 0 but the Feeds are still working (visible under Feeds). I already recreated the feedvalue and tried different Feeds but none is working.
What's wrong or what should i change?
Thanks for your help
Re: Problem - Dashboard-->Widgets-->feedvalue
I assume you are not viewing a public dash with non-public feeds, Do you have any symbols in the feed names?
Lost EmonCMS process list and feedvalue control values
krabu's picture
Hi Paul
Thanks for your answer to my question!
No, I've no symobls in my feeds. I've for example the name "Aussentemperautur" or "Temperatur_20_UD WE1 Heizkanal (Node3)".
I don't know what could be wrong.
Thanks for your support!!!
Ueli
